A4LD - Converter Clutch Override solenoid location 87 bronco ii
groovtubin
29
NC
Ford Bronco II
Is the Converter Clutch Override solenoid location 87 bronco ii LOCATED INSIDE the PAN, or outside? Thanks in advance, Ran the OBD-1 meter test its ONLY code i get ( 89 ) The Bronco will NOT take off in OVERDRIVE BUT you can SHIFT it manually into OD and it works going down the road, It was rebuilt before i got it bk on road, the connector is prolly hanginging somewhere lolololol
