Junk Collector
Truck of Month
- Mar 4, 2008
- 4,844
- Rapid City SD
- Engine Type
- V8
- Engine Size
- 5.0
You have a speed density engine setup, either computer will be fine. IIRC the only thing that the auto computer does that the manual one does not is lock or unlock the torque converter, otherwise NOTHING else on your A4LD is controlled electronically. If you had a newer vehicle with one of the newer automatics you might run into issues with this but not in your case.
