ABS Light and Emer. Brake Light
Kroeter
Ohio
V6 4.0
97 Ranger. Both ABS and emergency brake lights are on. ABS stays on Emergency light goes off and on.
Brakes work fine, is it a huge concern.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
CHeck fluid, its probably low.
Ranger97XL
if that doesn't work also check the ABS module thingy on the frame, underneath the cab, the plug was loose, cleaned it and sealed it with some epoxy lights went away
wvcat
I had some air in the front brakes on my 00 and both lights were on. I bleed the brakes and they went out. The brakes felt ok but are better now.
Kroeter
Ohio
V6 4.0
Thanks.... All is good now, nothing little brake fluid couldn't fix!!!!
