learningcircles
- Nov 11, 2011
- 0
- Mazda
Hi,
I have a 96 4.0 4x4 5 spd ranger that set up for about 3 months.
I just had new wheel bearings installed (that's why it was sitting up) and when I went to test drive it, it had no brakes!!
After I pumped the pedal furiously, some resistance came up, but it was very spongy.
When I took it around the block for a test drive and tried to slam on the brakes, it made a bad grinding sound and the pedal pushed back on my foot, hard.
The ABS light is also on in the dash now
What could the problem be? As simple as a little air I need to bleed out? Or is the slave/master cylinder dead? Is there any kind of ABS sensor that might be acting up?
