Air intake
maskeet
Mazda
3.0L
I have a 1994 Mazda B3000. Has anyone attempted to make a custom air intake?
thanks
Sunk
125
Everett, WA
3.5 Eco
What kind of custom? A snorkel or a cold air intake?
If you're after a CAI, you'll find that the stock set-up is already designed to draw cold air.
maskeet
Mazda
3.0L
I was trying to make an after market one for performance. Thank you tho because i did not know that. I have seen one with an electric fan in the line and thought that might be an interesting idea.
I wanted to know if anyone has tried to make one because they don't make any for my truck. (with or with out a fan)
Donnie strickland
This has been discussed many, many times on TRS forums, but the reason nobody makes one is because any other design won't make any more power. The things that limit your power are the restrictions in the throttle body, the heads themselves, and the exhaust.
maskeet
Mazda
3.0L
Thank you, I did not know that.
What are other performance mods that I can do?
Ranger44
23
Illinois
FORD
4.0 OHV
There really isn't that much of a restriction in the exhaust. You can only move so much air through a naturally aspirated engine(volumetric capacity). It's the atmospheric pressure that moves the air into the engine, and as was mentioned it's the TB, Intake manifolds, and heads that limit anything, but then again, an engine can only hold a certain amount of air in each cylinder, so what that point of shoving air down there, when it would make a difference. The best way to gain performance on your 3.0 is forced induction(supercharge or turbocharge). This compresses the air into the cylinder, and increases the pressure. This will yield power. Don't believe the flase performance hype, they just want to make money. Another good option for the 3.0 is the 5.0 roller rockers that bolt right into place on the 3.0. They decrease valvetrain friction, increasing the feel of acceleration, providing longer life of the valvetrain, and runs smoother and more quiet at high rpms. Always remember the 3.0 loves high rpms. It can easily handle them to, don't worry about hurting it. Assuming you have a manual, when shifting wait till 4,000, when you shift it'll keep you in the power band, which is largely above 3,000 rpm. If an auto is what you have, a programer (not a chip) will help cahnge the points at which your auto shifts, increases the feel of power, and giving your truck better acceleration. Ford hadn't quite figured this out on the 3.0 and made the auto's shift too soon for the 3.0 to reach it's power band.
maskeet
Mazda
3.0L
Thank you, have you tried the 5.0 roller rockers?
