Search google for equal. Not the sugar stuff, but looks like it. You toss a bag of it before seating the beads, but it could be funneled into the valve stem with the core removed.
I used (flame suit....on!) antifreeze. 8 fluid ounces in each of my 31" Explorer MTs.
I pulled all the wheel weights, pulled the valve core, hooked a piece of 1/4" airline to a pop bottle and slipped the air line over the valve stem.
Yes, I did a lot of reading before I did it. I would have gone airsoft or something but my OBA system in the jeep was run off a Sanden AC compressor that i had to feed oil to, so even after it was filtered there might have been a tiny bit of oil vapour in the air. Given that I aired down every weekend, sometimes twice on a weekend, i figured that the oil would turn stuff into a stuck glob of gunk.
In went the anti-freeze. VERY good results.
The antifreeze works exactly the same way as the beads. But it can't clump.
With any balancing system like that you WILL get a vibration until you settle out at a certain speed. Ex: Drive 80 (km/h) and it's smooth...accelerate up to 100km/h, it'll shake for about 2 seconds until the agent moves around and counteracts the vibration, then you're smooth again until you change speeds.
Something else that's a bit goofy with balancing agent is secondary roads. Ex, a back road that you travel around 80km/h on... Every time you hit a sharp bump (pavement patch, pothole, etc) the balancing agent will move, give you a shimmy for 2 seconds, then smooth out. if you hit a bump, then another bunp, then another bump...well, it can be interesting....BUT, the jeep was a solid front axle, coil sprung with a parallel trac bar/drag link, so that would amplify the shake.
Anyway, steel shot is a no-no, as is golf balls. Some people say that they had no issues with them, others posted pics of tires all chewed to heck on the inside. Also, steel/metal shot will make a heck of a noise at low speeds (not enough centripetal force to keep them on the tire and they hit the center of the rim as they fall off near the top of their arc).
I know that using antifreeze sounds crazy, but it had none of the drawbacks that the other agents had.
Also, coming home from wheeling with mud or ice packed in the rims was a lot more bearable because an agent that can move around can counteract that (to an extent). Better than lead weights, which can't adjust to changing conditions (mud or ice that throws the balance off, losing weights when wheeling, losing a bead and having the tire turn when wheeling, etc)
*Something to note also, was that the 31's were remolds, with a big block tread pattern (
like this), so they were a bugger to get a decent balance on in the first place. On the highway at 60mph I had a little shimmy in the steering wheel. When I say little, I mean small. Smaller than what I had after more than one attempt at conventional balancing.
