alignment tool
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
for a4ld. Must I use a real alignment tool and can I use the torque converter shaft to align the pump and bell housing? I saw on youtube a guy use the tc to align them but I just want to be sure it's ok.
Transman304
43
Morgantown WV
Chrysler PT
2.4
If you can’t fix it with a hammer, you have an electrical problem
Yes it wil work. Tool is best option but converter will get you there. Good luck.
8,372
Also often overlooked or simply not understood, is the engine transmission alignment
There are Dowels on the engine to align crank and transmissions input shaft
It is assumed the bellhousing is aligned for input shaft, what you are doing now
The dowels are there so the bellhousing is aligned with engine/crank when its in place
So give the dowels a look, make sure they are tight and not crooked, and the bellhousing holes for them are not worn
Even a small misalignment here will break the flexplate over time
croatankid
5
jacksonville, nc
4 liter
I'll do it myself
Thanks to both of you. I am relieved.
