Alternator pulley swap?
beerhunter
22
Hi all
I need to order a replacement alternator, but the ones with the right mounting points, and plug sockets, all show the 6-rib v-belt pulley.
Mine has the old fashioned single=v pulley. Are these all interchangeable? I.e. can I order one with the ribbed (for my displeasure) pulley, and simply swap over my old pulley?
Or are they not interchangeable?
Many thanks - disconnecting the battery every time I park up is getting old...
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,552
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I'm not sure I would trust the picture you see will be exactly what you get.
Try calling or emailing the company and ask them the question. The specs in their parts catalog should say what pulley is on it.
beerhunter
22
Thanks for the reply. I will do.
19Walt93
4,492
Canaan,NH
351
3"
235/55R16
Yes, they are interchangeable. I use my 1/2" impact to remove the retaining nut and recommend NOT getting your finger into the cooling fan when you pull the trigger.
alwaysFlOoReD
5,133
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
This. An impact is almost essential. That initial high speed torque will spin off the nut easily compared to figuring out a way to hold the shaft from spinning while using hand tools.
beerhunter
22
Thanks both. Always worth reiterating how much better it is to not squish fingers during a given task!
Uncle Gump
Token Old Guy
13,552
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
This operation probably wouldn't squish them as much as it would ripe and teat off your fingers.
beerhunter
22
Yeah, I was being flippant, but it's an excellent point, and we'll worth making.
