Anyone ever repair a shifter for an FM145 ?
bcschief
32
crescent city fl
2.9
As the title says anyone have any success in repairing one and how did you do it short of buying a $350 shifter ?
gaz
670
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
bschief,
What is broken?
29 years ago after installing a body lift, I lengthened my shifter. Years of use caused the little cup dogs to wear off.
Five weeks ago, while out for maintenance, somehow the shifter lower cup ball came up missing. I was lucky, just pulled a replacement from the wrecking yard.
Depending on what is actually wrong, there is room to repair some areas if you have the time.
bcschief
32
crescent city fl
2.9
This is not a Mazda transmission this is a Mitsubishi FM145 has a trapezoid shaped plastic mounting base to the housing. The shifters are obsolete and have been for years. I am looking to see if anyone has ever made an attempt at repairing these shifters. They get loose and you can rotate the shifter in the housing.
