anyone use these...
Pistons23
Fresno CA
2.5
Infinity Kappa 682.7cf
crutchfield said they wont fit behind the grille on the door. they said i have .525 between the door panel and the speaker mount and the infinity sticks out .625. can a tenth be shaved from the grille on the door panel? this for a 2000 ford ranger(regular cab). thanks in advance
nidf88
Carrollton. GA
2.8
thats just tweeter protrusion. they should fit no problem. worst case scenario you mave have to push the door panel on a little harder and the grill may bow out to make up for that .1 of an inch. but beware of the 2 ohm impedance! you can push them with just a radio but 2 ohm speakers are designed to be used with amps. the small amp built into the radio will get hot from the lower resistance in the speaker. heat+time=dead radio. The kappa series are known for being very bright speakers (the highs are very high).
Pistons23
Fresno CA
2.5
well i went with these 6.5" instead:
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=410&i=108607CS&tp=106
component speaker system includes woofers, tweeters, and crossovers
2-ohm system impedance (separate amp recommended)
6-1/2" Plus One+ woven-glass-fiber woofer with hi-roll rubber surround
1" M.M.D. dome tweeter with multiple mounting options
Starfish™ mounting bracket for easier tweeter installation in factory locations
2-way external crossover network (18 dB/octave, 3,500 Hz high-pass and low-pass) with adjustable tweeter output settings
power range: 2-90 watts RMS (270 watts peak power)frequency response: 45-25,000 Hz
sensitivity: 95 dB
Intermount III mounting system for fit in 6-3/4" openings
top-mount depth: 1-15/16"
warranty: 3 years
while i was my local stereo shop i picked up some 6x8 to 6.5" brackets so i dont have to make my own and some speaker wire. i really want to install them ASAP, but i dont want to kill my reciever. so im going to look into an amp. how much power can i run to these speakers? i was thinking of getting this one:
http://www.crutchfield.com/App/Product/Item/Main.aspx?g=120&i=113KAC6202&tp=115
nidf88
Carrollton. GA
2.8
you chose.... wisely.
mount the tweeters within 7" of the woofers, tweeters are directional.
as for an amp..... that kenwood will work just fine, but why not get a big 4 chan so you can do the rears later? the kenwood at 100RMS x 2 @2ohm should be just fine, you may even be able to fit it under the seat too.
remember the rules for wirirng 4 chan amps:
1. run power wire on the opposite side of the car than the rcas and speaker wires. if they must cross paths do it perpendicular (they "x")
2. use good rcas (>$20)
3. use the high pass filter (somewhere from 70hz to 120hz on your kappas)
4. at least 8 guage power wire for your amp. (4 would be better)
good luck!
Pistons23
Fresno CA
2.5
thanks for the reply. im thinking of getting the rockford fosgate p450.4:
60W x 4 @ 4-Ohms RMS
110W x 4 @ 2-Ohms RMS
225W x 2 @ 4-Ohms bridged RMS
i plan to get a 4 guage amp kit. later i plan to use the rear channels to power a shallow sub. im not even going to bother with the speakers behind the seat, ill probably just remove them. i can barely hear them anyway.
Pistons23
Fresno CA
2.5
sensitivity: 95 dB
warranty: 3 years
i noticed on the box that it has the 4ohm symbol next to a reciever and a big check mark. which made me think theyre compatible with 4ohm rated headunits. so i emailed infinity and got this:
Thank you for the inquiry. Yes, these 2ohm speakers are
compatible with your 4 ohm rated headunit. The actual impedance seen by
the head unit will much closer to 4 ohms and will not cause a problem.
I hope this is helpful!
either way, im removing the rear speakers and turning on the high pass filter. hopefully ill get them installed this weekend. next weekend i should have my amp
mfp4073
thats good info about the 2 ohm kappas and 4 ohm head units. I had heard for awhile that you could not use them without an amp that was rated at 2 ohm.
great post!
Pistons23
Fresno CA
2.5
yeah, but i still think im taking a risk. its only going to be ran off the headunit for a week. then ill hook up a ed nine.4 and install some e-edead on the doors
