2.3L ('83-'97) Are the cab mounts the same used for motor mounts? 89 2.3 Ranger
MaD
45
AZ
They look the same. Also when looking at them online i see another mount but i can't find them on my truck but there is a piece of rubber which im assuming used to be apart of the mount. Here is some pics. Thanks in advance!
svtcards
137
Lyman maine
302
3'' front 4''back
The thing u circled in red is a bump stop not a motor mount.its purpose is to keep frame from hitting the ibeam on heavy suspension loads.cab mounts are not the same as motor mounts.hope this helps
MaD
45
AZ
Ok, thanks so much. Are cab mounts replaceable? i cant find anything about them online.
svtcards
137
Lyman maine
302
3'' front 4''back
They are!That's the link I posted earlier. Rubber or urethane mounts depending on what u want.If your looking to change the rubber OEM mounts the link I posted is what u want.1 thing to mention depending how rough your hardware is they also sell a kit that replaces all that as well from same place.
  • Like
Reactions: MaD
MaD
45
AZ
Ah Thanks! i didnt see it at 1st.
