As-cast finish valve covers for SBF?
tinman_72
137
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
I have always thought natural aluminum finish (to match non-polished aluminum intake and heads) valve covers would look sweet on a engine. I am in the process of collecting parts for my '71 351W for my '72 F100. As-cast valve covers are all over the internet for Mopar and GM but not Ford.
I have a set of cast aluminum valve covers that are painted or powdercoated black. Does anyone know if I could strip the coating off and somehow work the surface to look like as-cast? Maybe sandblasting them or some kind of chemical treatment? I tried to Google it but I just get a million results on how to polish aluminum.
Edit: I did find a few such as these Trick-Flow covers at Summit Racing, but I do not want any text or logos other than "Ford" or "Power by Ford". Yes I could sand or machine the logo off but then there would be a smooth surface left and I would be in the same boat.
85_Ranger4x4
17,949
SW Iowa
Bird76Mojo
1,265
IL
I've had good luck using "Aircraft stripper" from Autozone to remove powdercoat in the past. It may take multiple applications in certain areas where it sticks a little better, but it's worked for me. After that, go from there. The finish may be what you want. If not, have them blasted with a course media. Glass bead media should provide the finish you want. For a while it will look cleaner than your intake's finish but give it time and they should match pretty well.
tinman_72
137
North Georgia
2.5 (4 Cylinder)
2.5
Factory
None
255/60R15
RoHS compliant
Those Mustang valve covers would have been my first choice but I forgot to mention that they have to be tall valve covers to clear my roller rockers.
Glass bead blasting sounds like it may be the way to go, thanks.
Bird76Mojo
1,265
IL
Come to think of it, blasting with aluminum oxide should provide the roughest finish from my experience.
