AVM Manual Locking Hubs for 98 Ranger
ozziemo27
June 2010 OTOTM Winner
18
Michigan
4.0 & 2.3
Thats exactly what i ask myself. Should I throw $150 or just leave the stocks locked inn. The thing is that I dont use the 4x4 very offten, so ill be wearing down the cv axles and what not, for no reason. Im totally confused on getting them.
Another thing is 60% of my driving is offroad (gravel/caliche) rocky roads, Im having doubts that those AVM wont handle that much hard vibration and bouncy tires.:icon_confused:
Just an FYI for my situation, i wheel a bit and have a torsion bar crank and 33s so i got extra stress but still. You'd think they would do better. I use 4wd quite a bit.
96Greenster
Rio Grande City
On the stock pulse vauccum hubs you can still make them selectable. Instead of pulling the hub apart and breaking the clips you can just break the little wagon wheel out of the center. Its been a while since I did this 2 my 99 since I have had the front cut off of it for a year and a half now. If you take that out and keep the inner clips you will be able to lock and unlock them like your pushing a button. If you want it in 4 wheel drive you push the hub clear back and allow it to release fully . If you want free you push it half way until it latches in the clips. Im actually going to do this to my 01 because i have had nothing but trouble with the live axle wheel bearings and my cv shafts are shot.
That sounds good. Ill look in to them. One is all tore up, so i just need one and do that mod. Thanx man.
96Greenster
Rio Grande City
Yep. Well thanx for all your help buddy. Ill figure out what would be best in my situation. I need to buy the front drive shaft pretty soon, then i figure out the hud dilema. Thanx again. Talk 2 u l8er:icon_cheers:
ozziemo27
18
Michigan
4.0 & 2.3
np, i wouldn't really be afraid to get another set of AVM hubs because i know that it was the hubs fault for failing, it was that little c-clip that made the shaft whip around blowing the hubs to pieces. I am going to give the stock hub auto to manual thing a try, it'd be really cheap and easy to find a set of stock hubs too and convert em to manuals. And if they break, it wont be as huge a loss
dangerranger911
Jacksonville, Fl 32225
4.0l
it probably wouldn't be a bad thing to take the plastic retainer clips to a machinist and have him make it out of billet aluminum or something and head the problem from the beginning. just a suggestion. if someone has a retainer clip they could send i could probably get some made.
96Greenster
Rio Grande City
I had to buy a set of those retainers... $40!!!! for two little "C" plastics!! Dealer only had them, so, whatever... Im prolly going to get me another set of stock hubs and give the manual lock a try. If i findem used, Or at least one...
ozziemo27
18
Michigan
4.0 & 2.3
i hear ya man, i paid 40 bucks too for them, im going for the manual lock OEMs too, im done with AVMs for now, they worked great til i shredded mine, i don't blame em, those half shafts were loose and whatnot. the clips got steel in em too, dont forget
masterbrenden
twin peaks,C.A.
ford/ford
3.0l v6/4.0l v6
i know this post is sorta dead but i have a suggestion for the hub coming off problem
what if you were to put a cv boot clamp (crimped kind) or something along those lines on the plastic clips that hold the locking hub on?
ozziemo27
18
Michigan
4.0 & 2.3
I don't see why that wouldnt work, i'd try it! :icon_thumby:
88gt
central VA
2.3t swap in prog...
my lord, that piece would be a pain in the ass to make!
MountainMike
84
Canada
245 CID
2"
31"
The fun begins where the pavement ends
ozziemo27
18
Michigan
4.0 & 2.3
plus how would you get it on the shaft? it would have to flex a little to get it to slide on and get to the groove
88gt
central VA
you would have to make "fingers" so that it would give a little to get in then expand out to lock in place.
ozziemo27
18
Michigan
4.0 & 2.3
what?
:icon_confused:
88gt
central VA
sorry, i was thinking about the clip that holds the hub to the wheel. the plastic clip that broke and were zip tied together ina previous post.
