Tractor Dan
- Dec 29, 2008
- 1
- Near Lima, Ohio
- Ford
- Engine Size
- 3.0
Truck starts leaking in July. Got it towed home and parked it. I have looked and for sure have to do the pinion flange seal and the axle shaft seals. Also found that the brakes need done and new drums. Gonna do the diff cover gasket while i'm there. So basically doing everything but wheel bearings unless i have to do those and for sure i'm not messing with the ring and pinion. That's the whole reason i swapped the axle in back in 2010. It was all set up and i just had to swap and go.
So my main question is how hard is it to get to and get that cross pin out? I'm sure i can do it i'm just not seeing how it comes out. I see in the tech article there is pictures but i'm trying to figure out where it sits in there? I'm sure once i get it all opened up it will be the light bulb moment and i realize i was over thinking it. I do that a lot.
Also do yall think i should replace the wheel bearings? They seem to have no play and it seems to be just the seals are leaking so if i can do just the seals for a few dollars each versus the whole bearing/seal unit for $20+ each i would rather go the cheaper route. Especially if it gets me back up and running. I generally do bearings and seals at the same time but figure if the bearings are solid why mess with what isn't busted.
Also the axle is in a 97 but the axle is actually out of i believe a 98 or 99. I know that shouldn't make a difference but it does when it comes to buying brake drums so i thought i would throw that info in.
