B2 no spark
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
I am looking at buying a 1989/90 B2 for $750 (or less) that has no spark. Or at least that is what I am told by the mechanic. What could be wrong with it?
Everyone I asked at the shop says ignition module or distributor.
3,614
Ignition module.
Or distributor.
Maybe the coil... but not likely.
Or ignition module.
lil_Blue_Ford
6,312
Butler, PA, USSA
4.9L
Ignition module would be my first thing to check - the infamous TFI module.... Autozone can test them.
Distributor would be my next likely suspect.
And yes, a coil would be on the list. I've had to put two of them into different trucks of mine - one because of no-spark and one because of weak spark.
And PLEASE use dielectric grease on all electrical connections! The one coil I had to replace because of weak spark - the end the plug wire hooked to was corroded halfway off because no grease had been used by previous owner(s).
wrecking-crew
25
dirty jersey
06 chevy
88 ranger
6 cylinders
One last question.
Is 750 a good price for this B2? Rust free or at least very little from what I can see. Interior is clean. manual t-case and hubs but automatic.
3,614
If it doesn't need anything major to get running that's a good price.
lil_Blue_Ford
6,312
Butler, PA, USSA
4.9L
Not a terrible price if it's in good shape other than the no-spark....
But I haven't spent more than $340 on a BII yet. Only one ran when I bought it (well, it would have ran if we had a good battery for it when I picked it up, lol). One was a no-start (fuel problem - turned out to be a half-baked wiring repair job). One was a cracked head problem and the last was a parts rig. The one with the cracked head I ended up putting a junkyard motor in, the other two were relatively easy fixes but also needed some bodywork.
