Whitbread
- Mar 13, 2017
- Reaction score
- 23
- Location
- Gaylord, MI
- Make / Model
- Mazda
- Engine Size
- 2.0L
- Manual
Lots of progress now!
Since you have to drop the front diff to get to the driver side motor mount bolt anyway, figured it was a good time to clean up the 4.10 junkyard front end and put it in.
The adapter kit is set up to use a 4.0L clutch, flywheel, and trans. So I snagged a 2010 4.0L 5 speed trans as my truck was a 3.0L. I pulled both transmissions down to install my shorter 3.0L 1st-3rd gear in the 4.0L trans with all new syncros, bearings, and swapped over my tailhousing with t case linkage mounts. I use this as a work truck out in the woods, so I wanted the lower first gear (3.7 vs 3.4). The only difference I found between the two transmission is the spacer that goes between 5th and reverse. Otherwise, everything was identical.
Adapter kit mounted up perfectly!
Had a slight interference issue between the front diff and the passat oil pan, so off to the parts stash for a jetta oil pickup and pan!
Quick baffle
Much more betterer!
Looks so little in there
Quick baffle
Much more betterer!
