Bad Leak At The Rear
Drg racr
Southern Michigan
I got the motor back in my Explorer. I took it for a drive, and noticed a huge puddle when I got back. I thought it was my rear main, but I don't think so now. I pulled the starter today, and the inside of the bellhousing is clean and dry. If it was the rear main, I would think it would be spraying oil all over the flywheel and TC. So, I'm thinking I must have pinched the oil pan gasket somehow. The oil is dripping right down the really long Torx screw at the back of the pan.
Am I going to have to pull the motor to get at the oil pan gasket?
There was a plastic strip that goes into a groove on the rear main cap. I didn't use it, because it looked like the oil pan gasket sealed that up anyway. Could that be my goof? :nopityA:
AllanD
TRS Technical Staff
135
East-Central Pennsylvania
1987... sorta
'93 4.0
The plastic strip is a "key" that keeps the seal from walking out of the pan.
Yes, you have to pull the engine to get the pan off.
AD
Drg racr
Southern Michigan
Oh, gotcha. I pulled the motor back out, and it was the rear main seal. It was pushed right out of the block and rubbing against the flywheel. I don't know how that happened, it was sealed into place pretty well.
I hope to have it back together later today and try it again.
96_4wdr
if the seal walks out again, purchase new seal, Felpro upgrade Teflon ring the best
dipple the seal seat in the block and pan with a hard sharp center punch in 3>4 locations around the circumference of the hole surface inside.
or lightly stake the seal in with a center punch on the outside edge of the seal hole in block and rear bearing/seal cap to hold the seal in place
