Bank 1 and 2 Problems
LMBACON55
4
Archer, Florida
Ford Ranger 3.0
Having codes P0171, 0174. Check for leaks, cracked hoses only found one the PVC elbow. I can reset fault codes but they come back in a couple of days. Runs good except for these issues. I am still having a acceleration jerking between 3K and 4k, only does it when its warmed up. I've replaced the air filter, MAF sensor and fuel filter. Can use some advice.
What's your fuel pressure?
8,372
Yes, test fuel pressure it possible
Lean codes mean the computer is having to add more fuel than it calculated based on engine size(3 liters), MAF data and 55psi fuel pressure
If fuel pressure is say 35psi then computers calculations will be off, but engine would run OK
decipha
5
New Orleans, LA
bunches
too many
take your pick
decipha
the most common cause for them codes coupled with the missing at higher loads is usually a failing fuel pump 100% of the time
remember you can only check fuel pressure drop at WOT
LMBACON55
4
Archer, Florida
Ford Ranger 3.0
Where is that at. The 54 I got was the rail pressure.
