Eddo Rogue
- May 18, 2020
- Reaction score
- 2,503
- Location
- Burbank,CA
- Make / Model
- Ranger 4x4
- Engine Type
- 4.0 V6
- Engine Size
- OHV
- Manual
- 2WD / 4WD
- 4WD
- Total Lift
- skyjacker front leveling kit
- Tire Size
- 31-10.50R15
- My credo
- Crossed threads are tight threads.
I figure instead of doing a bunch of searching just ask you guys. What's the standard for basic house framing? I want to build a simple lean to off the garage. 10'x16'. I only need the 3 other walls. I would cut a doorway in the existing garage wall. the two walls would be 10' out off the garage, and the end wall would be 16' across. I'm thinking the lean to roof would go from 10' down to 8' across the 10' span. So I figure 3 walls, and the triangle side filler headers (whatever those are called) is all I would need for framing.
Can I use the existing garage wall to build off of? Could I use joist hangers of the existing wall for the roof runners?
How would I build the 16' foot wall? could I just build two 8'x8' frames and attach them? would I use a 4"x4" to connect the ends in the middle?
for the 10' walls, could I just use 10 footers for my top and bottoms and just go 16" on center for the studs?
If I wanted to frame in a little garage door, would it be the same as framing in a regular door or window?
Can I just raise/attach the walls and anchor em down to existing driveway, or would I need to pour a concrete footer?
I am metal guy by profession with very little carpentry experience, mostly finish work. I did successfully frame in a skylight.
Any input, suggestions, questions, insults is appreciated.
