Battery light on
craveman85
new york
ford, AMC
2.3l, 2.5
Truck is a 2008 regular cab with the 2.3 and 5 speed. Battery light turned on yesterday. I checked my voltage this morning and it was 12.48. When I started the truck it jumped to 14.8. Any idea why my battery light would be in? Battery and alternator are less than a year old.
8,370
You will need to check voltage again after engine has been running at least 5min
Should drop to below 14volts
If it doesn't then voltage regulator in the new alternator has failed
Over 14v for extended period will ruin a 12v battery, cooks it
2008 2.3l Ranger will have a 2 wire plugin for alternator's voltage regulator(V6 engines use 3 wire)
Red wire should show battery voltage key off or key on <<< check this
Grey wire is the Battery Light wire, it should have 12volts but only when key is on.
It provides Startup voltage to get alternator working <<< check this
Battery light bulb gets 12v from fuse #9 in cab fuse box, and that passes thru the bulb and comes out at the grey wire on alternator, when alternator is not spinning it is, in essence, a Ground, a lower voltage, so with 12v on one wire and low volt(ground) on the other the Battery Light Bulb comes on.
After startup the alternator generates its own voltage and that voltage is fed back to the Grey wire thru diodes in the voltage regulator.
So grey wire would have 14.8v(in this example) and battery light bulb would also have 14.8v from fuse #9, if both connections on a light bulb have the same voltage then bulb is OFF, no current/electrons are flowing thru it to heat it up.
So your grey wire is not getting alternator voltage after start up, which would be a voltage regulator issue
This is not uncommon, but the more common issue for battery light being on after startup is alternator output dropping below Battery voltage, in this example 12.4v, so if battery light bulb has 12.4v from fuse #9 and under that from grey wire on alternator the battery light would have electrons flowing through it so would heat up and glow, the lower the voltage the brighter the bulb, flickering would be up and down lower voltage coming from alternators grey wire
Now the grey wire could be shorted to ground in the harness, worth having a look, but I wouldn't expect the alternator to start working if it didn't get the 12v FROM the grey wire to start generating voltage
So test Grey wire voltage(key ON) when its unplugged from alternator, should read Battery Voltage(12.4v) if wire is OK, if its less then there could be a short
An alternator is similar to an electric motor, the voltage regulator controls the voltage to the brushes on the rotor, if you don't shut off voltage to the rotor then alternator would drain the battery when engine was off, it would try to spin the engine via fan belt, lol.
But if you don't have voltage on the rotor then alternator will never start to generate its own voltage, thats the purpose of the Grey wire, Battery light is a bonus.
Grey wire gives voltage regulator 12v for the rotor so alternator can start up
Fuse #9 voltage is cut when key is off so when you shut off the engine, alternator's regulator has no voltage from alternator or grey wire so no draining the battery
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
14.2-14.5V is NORMAL for a fully warmed up engine (alternator) in ambient temperatures of around ~77° (voltage will also be slightly higher if colder outside (as well as right after the engine is started), and slightly lower (but not less than 14V) if warmer).
12V Lead-acid batteries (flooded-type or AGM) MUST be charged at these voltages. Less that 14V can actually lead to an undercharged battery and a higher sulfation rate (shorter life) of any battery in cyclic use such as in a vehicle (and today's batteries seem much more prone to this phenomenon than ones of 15 years ago as well, likely due to the increased use of recycled lead (resultant impurities) so you want to make sure it is always getting the proper charge voltage).
http://jgdarden.com/batteryfaq/carfaq9.htm#charging
(absorptive charging is the mode an alternator uses to charge)
I assume the 12.48V you measured was before you started the engine?
Does the light come on & go off at random? Or is it always on all the time? If the former, then there's may be an intermittent connection somewhere, which often can be difficult to find (a helper can be beneficial here, have someone watch the light to see if it changes status while you wiggle all the connections around the alt and in the power distribution box).
