bearings coparings
9
St Petersburg, FL
2.3
So I'm taking apart cap now looks pretty good and crank looks good, bearings defiantly getting worn they look original (ford emblem on them) My question is bearings that i got have a slot that's not on original? Is this a problem?
Red is original and blue is new bearing. Also another question how do i get both bearings off without removing crank?
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
lube and push bearing with plastic spatch to get moving. then fit new upper and use pic to rotate around.
tomw
46
toenails of foothills NW of Atlanta
lima bean
vertical and above ground
I used to use a short length of a nail. Cut the nail short, and then bend the head so it would be at an angle. Insert nail into lube hole in the crankshaft, turn the crankshaft and the nail will push the insert around.
If you get all the main caps loose, things will be easier to move.
The extra cut in the new bearing insert should have no effect. The old insert shown does not look too bad, but is worn to some degree.
tom
bobbywalter
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
i used alum rivet or soft cotter key to roll them before... to scared to use a nail.
tang to tang generally, hopefully your caps are marked.
9
St Petersburg, FL
2.3
Thanks guys for replies! I went ahead and yank crank off im to rough around the egdes to try the nail idea i would have sliced and diced that crank lmao! Here is some more pics I looks at other bearings and it is defiantly time for some new ones, I have to go get the connecting rod bearings aswell.
tomw
46
lima bean
I have seen a lot worse bearing inserts than these.
When you get the new ones installed, be sure to lube them, and check that the crankshaft rotates easily and smoothly after you torque down the main caps. If not, something is wrong in the clearance or installation.(or inserts)
Be careful when installing the rear main, especially if one-piece. There's a garter spring that can pop out of place if it is whacked too hard.
tom
9
St Petersburg, FL
2.3
tom
Thanks Tom will get this done this weekend. I have a question since Im in this deep should i go ahead and install new pistons and rings?
