Bed sags on 1 side
achampagne
Panama City Beach, FL
Ford Ranger XLT
On my truck, the bed sags on 1 side pictured below.
59791
I measured the distance from the frame to the top of the leaf spring and found that the right side is about 1" lower than the left. My first thought was the spring must be worn out on the right. I replaced both springs and the problem is still there. What else could be causing this. could the shackles be bad, or is the frame twisted somehow, etc.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
Front springs....frame twist and front alignment.... especially on a ttb truck, can do this.
achampagne
Ford Ranger XLT
It doesn't look like the front is sagging though, would cranking up my torsion bar fix it if they're worn?
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,680
woodhaven mi
FORD mostly
BIGGER
sawzall?
Hard to say
Frame may be rotten at the joiner and tweaked....many things possible. Ala trucks usually are better.
Need to check it.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Right side springs wear faster than the left, roads crown up to the left so the right side takes the most abuse. Check for physical damage from rust, bent stuff etc but it's not uncommon to just have the right springs flatter from typical use. When I use to build leaf springs I always made them slightly taller on the right to compensate for this. I assume Australian spring makes did the opposite.
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,875
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Look at the bed mounts. If it's like my 1998 was, the mount had rusted away. I fabricated a new mount and replaced the bed bolt and clip nut to fix it.
don4331
1,357
Calgary, AB
5.3
Your picture is small, but is the right side of the box a different colour?
If so I would suspect accident damage and have the truck checked at a frame shop.​
pjtoledo
3,020
Toledo Ohio
Fords
3.0 2.3
my 2000 looked about like that when it was new, except it's the front of the bed mis-aligned with the cab.
achampagne
Ford Ranger XLT
That's what I think it could be. The truck has a rebuilt title, but wouldn't it need to be inspected before getting that title. As far as damage, I can not see anything, and I have spent a lot of time examining the frame, just surface rust, and nothing bad. Now that I think about it, I don't know if it was like this when I got it. Since it is my work truck, I usually load stuff on that side first, but again, the springs are brand new and identical
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Mine leans passenger about 3/4. I think most of mine is coming from the front being low on the passenger side.
They all tend to lean one way or another. It's not an easy task to get a perfect set of springs. You would think they would lean driver side... being it has the fuel tank... battery... and always the driver. But I've seen more lean the opposite.
I would put it on level ground and take a few measurements... Front and rear. Looks can be deceiving at times.
