Behind axle tank the way ford shouldv'e done it
gaz
671
Wa, Bremerton 98310
87Ranger Endrigo 2.9l, 87BII Endrigo 4.0l
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
Deengineer until it is how Blue Oval should have sold it!!
Layout 5, new fuel door access site.
gaz
671
Wa, Bremerton 98310
Layout 6, bumper with receiver below to perform as rear cross member.
gaz
671
Wa, Bremerton 98310
Junglejoe
66
Columbia Missouri
6.0
1996 f250 auxiliary tank works BUT its only 19 gallons. Not to bad, just have to stop more often and stretch the legs on trips.
The b2 tank hangs to low, way to low on lowered trucks
gaz
671
Wa, Bremerton 98310
Here is the key mounting strategy for the BII tank forward, behind the Ranger axle;
There are some pre-drilled holes in the Ranger frame. 2 holes forward of the bumper (on the lower frame) is the hole I used to relocate the Rangers rear cross member piece. Use those holes for the new bottom attach point for the Ranger's rear cross member. Next hang the tank with BII straps and mark where the BII's forward tank support cross member holes lay. This puts the tank exactly where it should be if mounted forwards.
Installing the BII's forward tank support was facilitated by removing the driver's side rear shock tower mount, then reinstalling with bolts.
I will be taking it apart in the near future, I will take some more pics to clarify.
