Best $5 security system. What about an alarm?
auto117584
Mazda
2.3L
I'll be doing a bunch (BUNCH) of truck camping and backpacking. I won't to make sure the truck is STILL there when I get back, even if it's been broken into. However, I wouldn't mind some kind of detterent to breaking in, if there is such a thing.
So I'm thinking an inline switch or two, that break up two essential circuits (or two switches for the same circuit might be easier.)
Any body got the slickest set-up(s) immaginaeable? Or effective Imagineable?
ha ha
Imaginable!
yes. no red line under it
Thnsnks!
want
4.0B2
151
Walls, MS
4.0 v6
one thing you can do is have a wire that's hot with the ignition ran to an old car alarm horn... with a switch. that way if the ignition is hot with the switch open- the alarm will sound
another thing is to take the wire to your fuel inhertia switch and put a toggle switch inline with that. that will cause a break in the fuel electrical system and the motor won't get gas... so it won't crank, just turn over..
the neutral safety switch is another wire that can be switched and then the truck shouldn't even turn over...
is this the answers you wanted? or am i off base?
02RangerXLT
53
NE
Fuel shut off switch... battery disconnect... one of those bars that locks on your steering wheel... etc etc...
auto117584
Mazda
2.3L
I don't want to entertain the idea of the motor being started, even if a horn is blasting. With a running truck, they'd be motivated to find the horn and disable it.
The fuel inertia switch sounds like a good idea... it will crank but not start. I can hide it inside somewhere, under the dash behind the mouse family.
Actually, I can put a toggle in the neutral safety switch, and put it in an easier to find place, like in the driver's foot space, so the thieves will think "AHA!" if they get that far. I might want to hide the second switch someplace really inaccessible, for when I REALLY want the truck to be there, unless it was towed away. Hell, I don't want it towed away, either! Or pulled by chain.
So what for an alarm to deter potential crooks? And how about disabling it so it can't be towed with a chain or bar? That will be triple security, which, as a disabled Vietnam veteran, suits me just fine. Money is tight.
4.0B2
151
Walls, MS
4.0 v6
the inertia switch will turn over but not crank... so it just seems like something is wrong with it. the horn will deture some people, the horn should be mounted under the hood so it will take them a min to get to... therefore maybe you'll hear it.
Jason_J
5
Tacoma, WA
How about a quick connect steering wheel? I know for certain Grant makes one, other companies may as well.
3.0ranger1227
11
3.0L
Or Gwaii's method lol. even if they do get it started it would be a week before they got away.
But if you want real security get a boot. boot your truck
407Link
Orlando
that sounds like the best Idea.. I had a buddy make door latches that would shock you so bad you couldn't let go haha ran a taser with no pulse to under the latch and when you lift it, it would turn it on and had to have the alarm remote to turn off or know where the button was lol it got me a few times
RollinWOT
10
Cochise County
Ford/Kia
3.0L Vulcan/GDI 2.0L
I'm not familiar with the 2.3L, but if it has a distributor, just take out the rotor.
3.0ranger1227
11
3.0L
pull all the plug wires?
inuyasha2875
Post Falls Idaho
FORD
2.8,2.9
hidden push button start cig lighter is a good place to hide it
auto117584
Mazda
2.3L
what is Gwaii's method?
auto117584
Mazda
2.3L
i can imagine the wanna-be-thief throwing all boulders/rocks in the area thruough my windows, and putting a burning rag in my filler tube.
i'm still t hinking
auto117584
Mazda
2.3L
it has two things that have four spark plug wires coming out of them, each, but they're not distributors. dual plugs per cylinder
3.0ranger1227
11
3.0L
Gwaii has a ridiculous rock crawler. in absolute low low gear(he has 3 transmissions and 2 transfer cases going to 4.10 axles) the crawl ratio is like 6000:1. not practical in your application lol.
