- Jun 1, 2001
- 135
- Age
- 62
- East-Central Pennsylvania
- 1987... sorta
- Ford
- Engine Size
- '93 4.0
Underdrive pullies are a joke because of what MAKG said, particularly in
regards to the alternator, if you spin it more slowly the regulator will
simply increase the field current to compensate and it'll actually INCREASE the drag.
The power steering pump has a relief valve so at any reasonable engine rpm
you would be going straight and when the steering isn't being exerted you
could spin the pump wiht your fingertip.
On RBV's '94 and up the A/C system uses a cycling clutch, meaning the
compressor is intentionally cycled on and off with a pressure switch and
the cycling rate changes depending on the rat of evaporation in the
evaporator core.
On a 4.0 if you don't have 4.10's switch to them
The guys with 4.0SOHC's that have 4.10's usually complain less
about fuel economy than the guy's with 3.55's or 3.73s
Headers are ALWAYS more effective than most other mods
COMBINED (excepting gears), but few people are willing to
spend the price on headers.
I'm convinced that my 4.10 geared 5sp 4.0OHV with Borla headers would
hand out whoop-ass in large servings to ALL of the 5.0 (Non-HO)
converted Rangers I've driven. (to date I've driven four
different 5.0 conversions and one SBC conversion)
As for cold air intakes? you already have one and the companies that make aftermarket Cold-air intake systems exaggerate the effect they
give (IF claiming a gain when no gain is made can be described as "exaggeration")
Any any idea that there would be a gain from "Greater flow" presumes that the manufacturer would intentionally choke the engine
with the airfilter system (not bloody likely) which would cause emmissions problems.
AD
evaporator core.
AD
