best fuel injectors
Detroit
3.0L V6
best fuel injectors?
Hey all,
My friend suggested upgrading my fuel injectors to give the engine a little more power. I was wondering what brand, pressure, and flow rate are the best for a 145000mi 3.0. Also, would I have to change anything else with the engine if the flow rate is increased? thanks
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
What else has been modified on your motor that your buddy would suggest an increased fuel injector size?
In 1997, your truck would still use an EV1 injector so any fuel injector designed for a 5.0L mustang would work. But you need some serious upgrades before you max out the factory fuel injectors. When someone uses aftermarket fuel injectors, this is not to increase horsepower, but to deliver the correct amount of fuel for the massive increase in the amount of air their engine inhales. Most forced induction or extremely high revving high horsepower engines will require more fuel than the stock injectors can deliver, so then we must increase the injector flow rate to feed our new engine's fuel demand.
Tuning is required with larger flow fuel injectors.
Detroit
3.0L V6
ah, well then upgraded fuel injectors are pointless for me. All I have is an aftermarket exhaust. I might just replace them with oem ones because I have no idea how old the ones are that are on the engine now.
Gotta_gofast
33
Wisconsin
6.0L Powerstroke
Cheap insurance is to pull them out and clean them. You won't get "brand new" results, but a few cans of fuel injector cleaner and letting them soak overnight will help. Purchase new o-rings in case you tear some on removal or installation. Unless you have a leaky injector or one has a poor spray pattern I wouldn't waste the money to replace them. Check out Rogue Performance. Fred is very knowledgable with 3.0Ls and fords in general. He sold me an SCT X3 programmer with three custom tunes that I REALLY enjoyed. He also sonic cleans, rebuilds, flow matches injector sets in stock sizes for a good price if you are avid about replacing them.
Detroit
3.0L V6
ok cool. thanks for the info
trxusrngr
Manheim Pa,
That is Bluntly the best way to explain this typical scenario.... Well Put!
