BII Body lift advice
Andres629
11
Saskatchewan!
2.9 screamer
I've got 3" body liftblocks for my BII, got them free, but there was no steering extender that come with. What's the max BL height I can run without using a steering extender as well? Any info is greatly appreciated.
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
i think you need one for any body lift on a b2, i've seen some 2 inch BL kits that come with a steering extension. i'm sure there's some people that havent had any problems though. i bet you could rig up something with some scrap metal.
5.0B2
Helena, Montana
5L
I had to use one with a 2" body lift so I'm reasonably sure your 3" lift will require it. Call James Duff Enterprises - they are pretty easy to deal with.
Andres629
11
Saskatchewan!
2.9 screamer
Well I'm planning on cutting the blocks down to 2" so that's why I was curious. thanks for the advice.
PROFABBY
FORD
extend or not?
I just started on installing a 3" on my 90 b2. I was using a friends hyd. lift, and when i had the tub up to where it needed to be, I found that I really don't need the extender that came with the Performance acc. kit. I know it sounds wrong, but i turned the steering shaft by hand and there was no hint of a bind.
I did one on a '84 ranger years ago and had a hell of a bind. So in closing i'd say get it up and see what you got. Good luck and I hope this helps a little.
trail B2
8
North Eastern Ca.
My 2" needed a extender when I changed to a 93 column it didn't need one anymore.
92fordzilla
Burlington, Ontario
2.9L V6
did a 3" in a 92 ranger and didn't need any extensions. Guess some times you might get lucky and not need anything.
The_Dealer
10
Macon, GA
Duh!
1" needs nothing but longer bolts, people say if u gonna do it go 2 or 3 to make it worth it, but its not too involved to do(i can do a 1" in about 30 minutes with basic tools and a breaker bar)
