bii sitting level or not
timm667
ft.myers fl
1986 & 1988
bronco ll's
351w
should i add a 1, 2 or 3in. block?
sas and 5.5 eb coilsprings
5.5 bii leafspring
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
I think it looks good :headbang:
PetesPonies
25
east coast
2.3l
1" would level it.
Nathan123
Millersburg Pennsylvania
2.9 Litre
Going by the roof line, I'd say it's sitting pretty close to level. The front fenders are cut up higher than the rear, so it gives the illusion of sagging when sitting level, explorers are like that too. I personally like a little bit of rake, so if it were me I'd throw 1" blocks under it. Maybe 2" if your planning on carrying a lot of weight around in the back more often than not.
Brownie Mobile
Williston, ND
i second 2 in, your b2 looks sick though can we get some more specs?
TEK4x4
Currently Montana from North Idaho
Solid Axle Swap 4x4
i would only go an inch its so close.
timm667
ft.myers fl
1986 & 1988
bronco ll's
351w
86 bii
351w C6 np205
5in body lift
early bronco 9in. 513 limited slip
5.5 lift springs
long link traction bars
early bronco Dana 44 disk brake limited slip
5.5 lift coils, new buckets with duel shocks
extended radius arms
39.5 15 15 tsl
rhino lined floors
killduff shifter
to be added soon.
40in boggers
shocks
rear disk brakes
front drive shaft
lots of mud and a heavy right foot :headbang:
