BlackBII's white ranger
BlackBII
Ranger Custom
Truck of Month
982
UT
Added a roof rack to my camper shell today. I reinforced the mounting holes with some aluminum angle and added a neoprene washer. Hopefully it doesn't leak.
BlackBII
Ranger Custom
Truck of Month
982
UT
Finally found a manual steering box along with a 4wd(dropped) manual pitman arm. It's a slow ratio box which means I'll be turning my wheel about 100 times to turn around but this box will be much easier on my electric power steering motor and I'll be able to switch it off when I don't need it. :icon_thumby:
The input shaft is a 3/4 30 spline which means I'll need to find the right coupler or u joint somewhere as my current one is a 3/4 36 spline.
BlackBII
Ranger Custom
Truck of Month
982
UT
Found a 3/4 30 spline shaft on a Jeep Cherokee today. Luckily the DD shafts between an '89 ranger and first gen Cherokee are the same and it made for an easy swap.
Power vs manual
Cherokee shaft on bottom, ranger shaft on top
Both shafts shortened; left is Cherokee and goes to the steering box, right is Ranger and goes to steering column
Completed shaft. I used the rangers shafts' plastic inner sleeve fitted over the Cherokee shaft and rubber outer sleeve on both
BlackBII
Ranger Custom
Truck of Month
982
UT
Used some sharpie oil paint pens on my tires. I wanted to do red letters, but the paint pen was more pink than red so I went with white and some blue.
Also mounted the new black mirrors
turbo91xlt
63
Goshen, NY
1992
I did not think rbv manual 4x4 pitman arms existed, only ever heard rumors!! The manual box itself should be the same as any 2wd '83-'97 truck.
BlackBII
Ranger Custom
Truck of Month
982
UT
I'd never seen one either, but after calling 10+ wrecking yards around me looking for the just box itself, I found both. Interestingly, when I called they mentioned they had the box but the guy didn't know if it had the pitman arm or not. I just got really lucky.
After some digging, I found out that the GM 525 arms will fit the manual rbv box, along with older Jeeps and a few others, and those can all be found in any length and drop. Even straight ones made out bar stock that you can bend to your liking.
94b2300ranger
California
Mazda
2.3l is out! 4.0l is in!!!
A little clear RTV will ensure that the holes won't leak.
Truck looks clean, I like the simple look. Great job man!!:icon_thumby: The chipped paint just gives it character.
BlackBII
Ranger Custom
Truck of Month
982
UT
I need to pull the rack back off to mount some lights, so I'll add some. :icon_thumby:
Thanks champ. All it needs now is some paint. :icon_welder:
17,939
SW Iowa
Dad has a couple trucks with manual power steering, they are like steering a ship in a movie, hand over hand as fast as you can one way and then you have to repeat going other other way to straighten out.
BlackBII
Ranger Custom
Truck of Month
982
UT
Yep that's how my truck is now. It's kind of annoying but you get used to it. The manual box combined with the electric power assist makes turning the wheel super easy though, so that is nice.
The manual box requires ~3 1/2 turns each way. It's like driving a dump truck. :3gears:
BlackBII
Ranger Custom
Truck of Month
982
UT
Grabbed some center caps off an explorer at the wrecking yard
Painted them black and cut out the centers of the front two for my hubs. Also painted the knob on my warn hubs red to make them look factory
Also tinted my windows
someguy
Utah
This truck is clean!
When are you planning on lifting it?
BlackBII
Ranger Custom
Truck of Month
982
UT
Thanks! It's slowly getting to where I want it.
That's the big question I have too... I'm not sure. I have the coils, shocks, brackets and brake lines. The only thing I don't have yet is the steering and radius arms. I need to take a week off of work sometime soon so I can install the lift, build some radius arms and a custom k-link steering setup. For the rear, I think all I'd need to do is use the bottom shackle hole and add a one inch or so block.
It drives so nice right now that I think I'll drive it over the winter like this and then put the lift on in the spring. Plus, the 31" tires I have now are still basically new, and ~5 inches of lift and 31's might look silly. I want to run 32's or 33's but I don't know if I want to spend the cash on wheels(aluminum) and tires right now.
Also, the lock right locker in my 7.5 is misbehaving quite a bit... So I'm considering putting in a disc brake 8.8 and a different locker.
someguy
Utah
Let me know how that 8.8 swap goes, I hope I can do the same thing hopefully soon. As for the lift and tires, I would probably wait until spring too if I were in your shoes.
BlackBII
Ranger Custom
Truck of Month
982
UT
I will and I'll document it here. :icon_thumby:
It's definitely on the to-do list but it isn't a priority. I don't feel like spending the ~$700+ on the axle, brakes, gear set, locker, etc.
