- Mar 20, 2011
- 73
- Waveland Mississippi
- Ford
- Engine Size
- 4.0 v6 SOHC
Lol @ the chaos I started. You guys are awesome.
Gongo
Gongo
Welcome Visitor! Please take a few seconds and Register for our forum. Even if you don't want to post, you can still 'Like' and react to posts.
You mean like this guy?I cant believe you all. none of you remembered the most important aspect of vehicle maintenance. You have to flush your engine with saltwater every oil change, then run it for about 10 minutes before putting new oil in so its nice and dry!!!!
http://mustangforums.com/forum/5-0l-general-discussion/368307-im-done-with-this-car.htmlMy car was idling like crap the other day so I figured since I just got it, it may have been awhile since anyone changed the oil out. I decided to go ahead and change the oil. I used Mobile 1 synthentic oil like I was reccomended on here. Anyways, I drain out the oil and noticed it was extremely dark and even after 10 minutes of draining, it was still coming out. I decided to go ahead and flush it to make sure all the bad stuff got out. I hooked up the hose, ran water through the engine, started it up and was waiting for the water to come out clean (The engine never went above idle so I was told this would be ok). Anyways, About 3 minutes into this, then engine starts shaking and shuts off. I figured it was all cleaned out so I plugged it up, added the oil and figured I was ready to go. WRONG! The car won't freaking start now. This car has been nothing but trouble for me, I think I am done with it.
WOW! That guy really should never touch a car again
i've put tranny fluid in the oil before... and i did it intentionally...I have done some stupid stuff in my life but NEVER that dumb
bwahahahahahahawhat about the guy that put NOS energy drink in his motorcycle, thinking it was octane booster?
idiot indeed, but it wouldn't cause nearly the damage that they are all making it sound like... it COULD cause the fuel filter, and injectors to get plugged, and possibly gum up other parts, but unless it's 100% plugged (any of the parts) you can fix the bike without removing any parts... all you would need to do is drain the remaining high performance energy fluid, put in 94 octane gas, and methyl hydrate, (i would do 1part methyl to 3-4 parts gas, but most mechanics would recommend 1:10 or something like that) and run the bike... sugar is the only thing that is a big risk of damage, by gumming anything up, if it hits the combustion chamber, it will burn most of the way, but if it plugs a fuel injector, it's plugged and will probably need to be replaced... if it still sprays a little, it can be cleaned out...
