Blow Me
gsp
Weiand 174:
Tominator
24
Cahokia, Il.
5.0 S-Trim 450HP
So...your finished???:icon_confused:
gsp
Mounted, IT FIT!!!
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
Nice!
Does it fit under a factory hood?
gsp
gsp
Got to cut the hood,,,, well,,,, it needed cold air,, these blower generate a lot of heat:
shane96ranger
221
Utah
Ford F150-Stang
4.6 Triton / 5.0
May as well make a nice hood scoop!
BTW, I really like those valve covers.
EDIT: Was the "neck" on the oil filler already in those covers, or did you put that in there?
gsp
It was there, they are valve covers for EFI motor, but I simply vented them to atmosphere ,,, no PCV... I had to give up the valve covers, among other things, that came on this motor to help with a price break.. This was a new motor when I purchased it,,, 2009 casting.
Twister
17
Omaha, Ne
Duh
5.0L, 2.9L
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
That's what my engine needs next.
Sent from my SPH-D710 using Tapatalk 2
gsp
Only 4 challenges left:
1. Fabricate serpentine idle/tension pulley mount
2. Shim crankshaft blower pulley
3. Mount radiator, some how
4. Install wide band controller
5. Cut the hood
gsp
Cut the lower core support and made my own:
Tominator
24
Cahokia, Il.
5.0 S-Trim 450HP
Yep....like myself...sweating the little stuff now....my hands are full of scabs and every step forward has a few steps back.
Nice build you got going on!:headbang:
pengintamer
What kind of car is that radiator for?
