Blower issue
sean92
Winnipeg
Hey all,
My blower motor in my 2008 Ranger stopped working. I replaced the fan and resistor, and it was working fine. During the repair, there was corrosion on the connector to the resistor and was poor contact...but good enough I felt, as a new connector would need soldering, and none were available locally.
The air stopped working again, a few weeks later, and now, I have cut the old one off, and soldered a new one on. I'm decent with electronics, so soldering wasn't difficult. After connecting everything, I still have no fan, and I'm kind of at a loss of what I have to do now to fix it.
Any ideas?
franklin2
1,769
Virginia
Bronco II
Since you are decent with electronics, all you need are the schematics correct? It would really be a breath of fresh air to run across someone that is not afraid to figure out the wiring diagrams . Here they are for your blower motor.
sean92
Winnipeg
I just tried something I should have tried first, the motor. Connected a lipo pack to it, 14.8V, not enough to be too much for the motor. I didn't even see a spark when I touched the leads to the connector, not the faintest sign of like. So...my new motor died in a matter of weeks. I wonder if the bad connector for the resistor did it, perhaps causing fluctuations in current.
franklin2
1,769
Virginia
Bronco II
Cheap China junk most likely. It should have a warranty? So you can go get another piece of junk? But what do you do?
sean92
Winnipeg
I don't think there still is, my truck has been sitting a while. Where I am, I don't need a vehicle to get to work or to the store.
I guess these things aren't very good quality.
8,372
Unless its Motorcraft, or AC-delco, the parts were never tested before being shipped, labor to test parts is too expensive, even over-seas
Motorcraft parts are tested, Ford requires it, which is why they are so expensive, can be 3 or 4 times the price of a 3rd party part
Its cheaper in the long run for Ford to pay upfront for parts to be tested than to pay a dealer to replace a failed part, and of course owners dissatisfaction
I am sure "corners are cut" when a manufacturer knows they will not need to test parts just ship them out and let buyer "test it" and then replace it "under warranty" if it fails
In the case of a blower motor, which is easy enough to swap out, I would stick with the cheaper part, even if its out of warranty, they will not all be bad, for sure
In the case of fuel pumps..............motorcraft all the way, too big of a pain to swap out, lol
Burnsy
72
Hudson fl
Ford ranger
Was the motor the problem ? I wish people would post thru to the end of their experience
