- Jul 29, 2023
- 412
- BC Canada
- XLS Bronco II
Back in the day we had DOT 3. And DOT 4 was for heavy vehicles like motorhomes.
DOT 3 and DOT 4 both have a tendency to absorb water from the atmosphere, so always make sure to keep the cap tightly on the bottle. If you have old brake fluid, it's probably safe to assume it's contaminated with water and would eventually rot your brake line from the inside out and cause evaporation bubbles in hot weather.
DOT 3 is basic and ok for light cars but in my experience, a big car like a Camaro or Galaxy or a Truck, you'll never get brake fade with DOT 4 as it has a way higher boiling point.
DOT 5 is Silicone based. So you cannot mix it with old DOT 3 or DOT 4. If you build a whole new system, you might want to opt for DOT 5 as it is the best. But you cannot mix the 2 types. Once you fill a new brake system with a type of brake fluid, you should stick to it.
