Brake light flashing
KevinSonOfDad
ASE Certified Tech
44
Utah
Mazda B4000
4.0 OHV V6
having a weird issue where when i push the brake pedal the brake light comes on for a second but then goes back off. this happens every time i move the pedal until about halfway down it comes on solid. also only happens when the truck is running. when its off the lights come on solid like they should
superj
2,732
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
kind of like how new cars flash the lights when you push the pedal and then they go solid? maybe a ground issue back at the light assemblies?
rusty ol ranger
2.9 Mafia-Don
7,756
Michigan
177 CID
My 87 does this to. I blame the brake light switch on the pedal. I havent fixed it
KevinSonOfDad
ASE Certified Tech
44
Utah
Mazda B4000
4.0 OHV V6
Just took a look and it looks like the play in the pedal is the cause. The brake light switch gets engaged initially then the booster takes up the slack and it gets disengaged
