Broke ignition accuator rod
Rangerblue
10
WV
This is on my 99, the sliding accuator rod is broken, after looking I think it broke before and they glued / used epoxy to put it back together, I haven't took the colum apart yet but have researched the part and it looks a bit different than I picture in my head, https://www.amazon.com/Dorman-47510-Ignition-Cylinder-Actuator/dp/B07KLQJ844/ref=asc_df_B07KLQJ844/?tag=hyprod-20&linkCode=df0&hvadid=316725397836&hvpos=1o1&hvnetw=g&hvrand=12396868091915266002&hvpone=&hvptwo=&hvqmt=&hvdev=m&hvdvcmdl=&hvlocint=&hvlocphy=9059871&hvtargid=pla-635849017884&psc=1
Is this the correct part ? I can still use the truck now starting it manually with the ignition switch
Dirtman
13,327
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
So the problem is... the part you looked up doesn't match the part you imagined in your head? :icon_confused:
I uhh... ummm....
Josh B
1,987
Oklahoma
It may be possible that's the best way to repair one, epoxy, unless they just did that prior to flipping it over on you. There's some tough stuff on the market now, most of it can be found at auto parts stores or even wmart(same stuff, same brands, different prices). If you try it you'll certainly want to clean off very well whatever their "repair" left behind with a brush or a file, prior to attempting it again
29
San Marcos, Texas
B3000
Their listing for Rangers starts at 2003 yours is 1999. Or are you working on a different one?
Ray
ElectraRider
107
Colorado Springs Co.
Ford ,Ford
2.9 ,4.0
I went to a web site FordF150.net that showed that exact part and how to disassemble it and put it back together took him 6 hours. I typed in Ignition cylinder actuator rod for 99 ford ranger and that is what popped up might check that out.
rusty ol ranger
2.9 Mafia-Don
7,592
Michigan
177 CID
Slide a pipe over the broken pieces to put them together, then, bolt the ends down. Good as new
