bobaloo
- Aug 19, 2008
- 1
- Casco, Michigan
- Ford
- Engine Size
- 4 Banger
I was having a problem with a VERY bad idle. I needed plugs and wires so I went for it. Well, it was better but still missing. I drove it for a day with fresh gas and some fuel treatment. Still was running rough so I started doing diagnostics. Used my EEC-IV code reader and it said nothing was wrong! I started checking connections. Now it won't start at all!!! I pulled the ignition module to have it checked and found the broken wire that came out with the harness that contains the lower plug for the module and the connection for the Crankshaft Position Sensor. The end of the wire was green and corroded but I can't find where it came from!
Yes I have fuel to injectors, but now NO SPARK!
1994 2.3L
Please Help!!!
TIA
1994 2.3L
Please Help!!!
TIA
