Broken vacuum tube that controls the A/C
civildefense
st catharines ontario
Sport 4x4 v6
So I noticed some fluids dripping from the rear of the engine, lifted the hood, reached down to pull out the ATF dipstick and heard a crack like a dry twig.
There is a light grey thin hard plastic tubing that runs along the passenger side of the engine and I have broken it in half. Of course its about an inch from the rubber plug that seems to attach to and doesnt appear that I can push the broken end back in there. My question is, if anyone has experience this, can i find some sort of super small vac hose to fix this, a bit of heat shrink tubing, where am I going to find
the name of this part.
I havent found much about this particular issue probably because I dont know the proper name, but i am suspecting my air conditioning is not going to work until I fix it..
8,374
Yes, you can splice it with a small rubber vacuum hose, don't need clamps, heat shrink or anything, just a snug fit, its a VACUUM hose, so pulls together doesn't try to push apart connections
Just cut off a small section from the remaining longer grey line, and take that with you to autoparts place, you will have to buy at least a foot of the rubber stuff, lol, so using 6" instead of 2" is not a big deal
Next time at a wrecking yard grab a fitting with longer hard plastic hose for splicing, its not a "Ranger" specific hose, any vehicle will have same vacuum hoses
That Grey hose won't be a vacuum leak, its only used to SHUT OFF coolant flow thru heater core in MAX AC setting, which may allow 2 or 3 deg more cooling in the cab over time
So AC will still work fine, in any setting
That grey hose runs to the firewall, where a black hard plastic hose will go with it thru the firewall
Picture here of the two hoses from inside the cab: https://www.explorerforum.com/forums/attachments/2010-05-31_211033_inertia_switch-jpg.77025/
Top of picture, grey line connects to white line, black connects to black
Shadowrider6661
D RANGED
ASE Certified Tech
129
Off grid Northern Arizona.
Stock
4"
N/A
33 x 12.50 x 15
Drive it, Break it, Fix it, REPEAT !
Welcome to the club.
civildefense
Sport 4x4 v6
Its been a bit of an adventure, this truck, thanks for the good info i was really worried i would have to replace this part.
civildefense
Sport 4x4 v6
I spoke incorrectly when I said grey tube it is actually black, and I am pretty sure its preventing the HVAC to do anything but go on defrost. I took a bit of the broken bit to the parts store and he said he didn't have anything that small, so i think i am just going to replace the entire part. Do you happen to know what it is called or recommend a good book for parts diagrams and the like, there seem to be many different brands of service manuals out there.
SenorNoob
622
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Try another store? They should have fittings and even the plastic line. Try asking for Dorman 47432 and 47417. That's a connector kit and 1/8 nylon vacuum line.
Bird76Mojo
1,266
IL
I fixed my buddies Ranger using some weed eater fuel line I had laying around. He drove it that way for over 200,000 miles. I laughed every time he popped the hood and there was that yellow weed wacker fuel hose.
8,374
Yes, the black line is used for the Vents in the cab
Defrost is the default-no vacuum, air direction
Yes, try another parts store, never had a problem finding the small diameter rubber hose for repairing the hard plastic lines
