Bronco II Headliner Replacement
ford4wd08
513
Alcoa, TN
2.8 V6
Hi Guys,
As I continue to work on my BII, I've decided to go ahead and replace my headliner.
I pulled it down this weekend, and removed the nasty ass old material. My granddad thought it was a great idea to use a staple gun to hold it all up at one time..... I'll work through that with the repair.
Anyhow I am going to repair the foam backing board as it was already cracked before I took it down. I plan on using resin and fiberglass mat to repair it.
My question is about the foam padding that was above the head liner. It looked like carpet padding almost.
I tossed it in the trash... It looked pretty nasty.
What can I replace this with? I was thinking some sort of peel and stick closed cell foam? Any suggestions?
ford4wd08
513
Alcoa, TN
2.8 V6
I'll have to snap some pics tonight, but I have been working on this the past couple of evenings.
I have taken masking tape and fiberglass resin t repair the cracked and broken pieces. I plan on using fiberglass cloth on the area that cracked from the back side so they will stay together.
I can't decide if I want to recover it, or pay someone to do it.
I need my XLT door panels recovered as well, they are in good shape, just sun faded from 35 years of southern sunshine....
jjfugler
TRS Member
5
Baton Rouge, LA
Ford Bronco II
The Cologne'
I have added DynaMat to my bare roof and will add DynaMat and DynaLiner to my floor once I pull the carpet. Good luck with the headliner board. If you need a replacement I have one spare.
Luc_fraga
Fraga#14
Ford Bronco II
Where did you find a spare? I am interested in your spare headliner.
jjfugler
TRS Member
5
Baton Rouge, LA
Ford Bronco II
The Cologne'
I bought a donor and it had a better one in it. I really want this other one gone and to someone who can use it. Where are you located? I’m in Baton Rouge but travel quite a bit so could get it to you or close to you depending on your location.
Luc_fraga
Fraga#14
Ford Bronco II
Oof, I’m in Jacksonville area. I don’t really have anyway to meet you. I just putt around the beach in the B2. Thanks anyways tho
jjfugler
TRS Member
5
Baton Rouge, LA
Ford Bronco II
The Cologne'
Jacksonville Florida? Does getting it to Birmingham AL help? Or Savannah Ga?
Luc_fraga
Fraga#14
Ford Bronco II
Not really, but thank you so much. I’m not very mobile, I’m a full time student.
Austin Hughes
Florida
Ford Bronco II
Bit late, but is the
Bit late. Is the headliner by chance still available?
