fuel filter?
cracked distributor cap?
fuel pressure?
that one module thingy on the distributor that the 2.9's have issues with?
IAC?
dirty throttle body?
dirty/bad gas?
without some looking/searching on the B2 itself, there are A LOT of things it could be. I'd start with fuel filter.
It has a air charge temp ACT and a MAP the ACT is in the intake plenum pull it out and clean with rubbing alcohol or electrical cleaner and put a new vacuum line on the map sensor. Disconnect the battery while your doing that you must reset the computer when cleaning or replacing any sensor. Run it for at least 20 minutes somtimes it takes a couple warm up cycles for the computer to set new values. Replace the PCV if over a year old and all vacuum lines that are hard or cracked.
For
a small yearly donation, you can support this forum and receive a 'Supporting
Member' banner, or become a 'Supporting Vendor' and promote your products here.
Click the banner to find out how.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
