- Feb 28, 2001
- 4,493
- Dayton Oregon
- Ford
- Engine Type
- 2.3 (4 Cylinder)
- Engine Size
- 2.3 Turbo
- 2WD / 4WD
- 4WD
- Total Lift
- 6
- Tire Size
- 35"
It's TIGHT in there but I think I found room... Made some progress today, plasma'd the axle end brackets out that I sketched up yesterday, got those cleaned up then loosely bolted two bushings in there to get an idea on fitment and tacked that assembly in place. Passenger shock body would have contacted the upper link so I lobbed off the mounts at the axle, I'll relocate them outward about 1.5" I think, I'll do that last... Dealing with tube is different, I over estimated the tube length by about 1.5" on my first cut but I think this project will only take one of the 4 tubes I got... The top tube is done, it'll be dang near flat so from what I've read should work great.
I found some steel pieces that I thought would make good shackles but I think I'm going to plasma some bigger ones out, the 1" wide 1/4" thick strap just doesn't look right even though I'm sure it would hold... plus they have holes bigger than 1/2"...
The top link is 41" long, from where I have it set to go it will end up right at the rear body mount, conveniently there's a hole in the frame there already.
Next step is to make a front bracket and shackles...
I will note the Harbor Freight welder and plasma cutter are making this project nicer, the axle brackets came out pretty clean, used their magnetic tool holder things (the black bar magnets) as a guide for a few cuts which is a game changer in itself. The Titanium Mig 175 is a beast so far with .035" flux core wire, welds look good with plenty of penetration. I haven't tried the plasma on the tubing but I'm sure it would help, might do that next time, we'll see...
