An alternative to changing the tensioner or idler is to re-grease the originals.
IF the currently installed bearing is still smooth running, this process might increase the lifetime of your current tensioner/idler.
In most cases, the grease eventually dries out, and quits lubing the bearings. You may be able to disassemble the bearing, or at least remove the seal and clean and inject some new grease. Most seals are pressed into the sides of the bearing, into the outer race. They can in most cases be pried out of the bearing, and set aside while cleaning the bearings of old grease and 'whatever' has found its way into the bearing. Once clean, you can use wheel bearing grease, pressed into the race, bearings and separator to provide fresh lubricant to the bearings. Press the seal back in place, and re-assemble the idler or tensioner. The bearings are the only real 'wear' point in the idler/tensioner, so the rest should be fine.
If you have a removable tensioner pulley, Rock has one available that is the same as the tensioner for the 1985 model year, BUT, the assembly is made using a riveted 'axle', complete with a shoulder to position and square the 'rivet'. Removal and replacement would require a shouldered bolt, which is not available from my searching. The pulley and bearings are identical to the OEM. If you can remove your tensioner pulley, replacement of the pulley & built-in bearing are possible. You must have a removable 'axle' that the pulley rides on, or access to making one.
tom
