BW441 AWD case
mrtaco
MD
Ford explorer
Can anyone tell me if a explorer/mountaineer AWD transfer case will bolt to a 03 ranger 4.0 manual 4x4 manual trans?
don4331
1,352
Calgary, AB
5.3
Maybe:
We need more information on the Explorer case - date model (should have 4 numerical number after the 2 alpha characters) engine transmission
Picture are worth thousand words.
mrtaco
MD
Ford explorer
Thx for the reply. I was under the impression that there was only one true awd case. The bw 4410 and only one manual trans available in that rear ranger?
don4331
1,352
Calgary, AB
5.3
So, if I'm interpreting correctl; you are asking if BW4410 off '03 Explorer with 4.0 SoHC* & 5R55W will fit '03 Ranger with 4.0 & M5OD R-1HD:
Reader's Digest answer: no.
Novel length read:
The Ranger M5OD R-1xx uses a 5 bolt basically round pattern pattern on an extended housing, while the BW4410 uses a 7 bolt trapezoidal pattern bolted right to back of transmission.
There are 5 Ranger manuals in '03: (smart @$$ response below, and there are 6 versions not listed as they weren't available in North America and/or '03)​
2.3 M5OD R-1 2wd​
3.0 M5OD R-1 2wd​
4.0 M5OD R-1HD 2wd​
3.0 M5OD R-1 4wd​
4.0 M5OD R-1HD 4wd​
5R55W's in Rangers use an adapter from the 7 bolt pattern of transmission to the 5 bolt pattern of the BW1354 and extended output shaft.
Replacing the rear housing of the M5OD R-1 with one that would bolt to the BW4410 would be seriously expensive proposition - 3.0 to T-5 bell housing runs $2k and that was simpler casting with small volume production.
*I'm not sure if the 4.6 engine Explorer with 5R55S has same transfer case or not.
mrtaco
MD
Ford explorer
Excellent info. Basically I want a 5sp manual 4.0 sohc with a true awd. Looks like I’ll be researching the earlier transfer case found in the earlier 96 to 01 trucks
don4331
1,352
Calgary, AB
5.3
The easiest AWD solution for Ranger is:
The Dana 28 found in Aerostar: Bolts up to your transmission, provides AWD = 30/60 split I believe but no low range, wiring will allow it to be more/less locked in a 4 High setting. If you search forum you can find examples of its execution.​
The ultimate solution:
http://www.northwestfab.com/5-bolt-ranger-to-6-bolt-round_c_808.html
Then you can install a np242 transfer case with 2 High-4AWD-4 Lock, Neutral & 4 Lo.
np203 is alternative, but a little heavy for Ranger with 4.0 and I don't think it provide 2 Hi.​
np144 also works, but doesn't provide 4 Lo. And you would need to be creative to get 4 lock - wiring for motor and position indicators.​
New Process transfer cases have an actual differential for AWD, versus a clutch in the Borg Warner transfer cases.​
Some adjustment to driveshafts is also required with any of the New Process transfer cases.
mrtaco
MD
Ford explorer
I’ve read about the Dana 28. I font think it’s a full time awd unit and it would probably wear out quickly. What about the 4404?
don4331
1,352
Calgary, AB
5.3
BW4404 is more/less older model of the 4410; it uses viscous coupling to add power to split power as required.
I'm not sure how much difference there is between a Dana 28 and BW4404 - it almost looks like BW purchased Dana's transfer case division - but I'm not aware of that history.​
I'd be bigger fan of the 4405 - basically 4404 with 4 hi lock + low range of the 1354 - Explorer shifter was 4-Auto, 4 - Hi and 4 - Lo if I remember correctly (I'd have to look at my niece's to be sure.)
Wouldn't you need an Explorer PCM/GEM to control either 4404 or 4405? And I'm not sure how well they would work with '03 dash/manual.
snoranger
Professional money waster
ASE Certified Tech
13,677
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The 4405 is an electronically controlled auto 4wd. It senses slip between the front and rear driveshafts (speed sensors in the T-case) to know when to active “AWD”.
It should be able to easily be made a stand alone system using the selector switch, gem, torque on demand relay, transfer case, and wiring.
Using all 95-96 parts, it would have 2wd, 4wd high auto, and 4low
Using all 97-01 parts would give you 4wd high auto, 4wd high , and 4wd low.
Using the electronics from an Expedition with the Explorer T-case, you should be able to make a system that gives you 2wd, 4wd auto, 4wd lock, and 4low... I say should because I started researching it and found the systems use the same signals, started collecting parts, but never finished and tested it.
mrtaco
MD
Ford explorer
This is a street project. Not interested in a low range. So far I’ve learned that the 4404 awd case has a 31 spline input and I will have to swap my trans output shaft to one off a bronco/f150. I know they both have the round style flange from looking at pics. Does anyone know if all bw flanges are the same?
don4331
1,352
Calgary, AB
5.3
The 5.0 4404 will have 31 splines input and 6 bolt round flange. 4R70W/M5OD R-2 has 31 spline output/6 bolt round flange.
The M5OD R-2, the one out of Bronco/F-150/T-Bird, is completely different transmission, only bolts to something with SBF pattern - 3.8/4.2/5.0​
All Ranger transmissions have 25 spline outputs and 5 bolt flanges.
I'm not even aware of someone who make a 25 to 31 spud for you.​
mrtaco
MD
Ford explorer
I read that all the Mazda m50d r2 s were very similar minus the bolt pattern and output shafts. I did not know one was 5 bolt and the other was 6 bolt thou.
mrtaco
MD
Ford explorer
What is the np 144 used in?
mrtaco
MD
Ford explorer
What about the 02/03 4 dr explorer manual trans and 4410 awd case!?
don4331
1,352
Calgary, AB
5.3
Np144 is found in AWD Durangos.
I have never seen an '02 Explorer 4 dr with manual - not saying they don't exist, I've just never seen one. Would right up there with the 3.0 T-5 bell housing on unicorn scale.
I have a '02 Explorer 2 dr on driveway, but it has BW1354.​
Just for reference the M5OD R-2 tail housing has 1 more bolt than M5OD R-1, so I don't believe they swap.
If I was real industrious, I could get you pictures as both are in garage, but they are kinda buried, so there would be some garage cleaning involved. And if I start that, the wife would want the job finished.​
