Cams in the 2.9?
SWE_lollo03
Sweden
I've been looking for new cams for the 2.9 to get some more hp out of it but i haven't really been able to find any for hydraulic lifters except stock ones. Would cams for mechanical lifters work or does there need to be certain holes for the oil to pass thru or does anyone know where you can get a camshaft for hydraulic lifters?
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,515
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You could try Tom Morana.
@gaz might have some info for you also.
gaz
671
Wa, Bremerton 98310
Ranger 5" (1½" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 33"/3:73LS
@SWE_lollo03 ,
The lifters on these do not lubricate the top end. There have been some that have swapped to solid lifters, I do not appreciate the advantage in this application.
Melling, Sealed Power and a couple other reputable companies make the hydraulic lifter used in this 2.9l and are VERY reasonable.
If you chose to use a more aggressive cam, you can expect to need a stronger set of valve springs; they do not need to be top dollar designers, I have used V8 dual springs sets that fit the bill.
In regards to the cam, I recommend having a custom reground at ⅓ the cost, verses buying a replacement, unless your is broken. There are several good cam grinders and builders near me; they are both more than capable of regrinding your cam or selling you a "cookie cutter" (one size fits most) premade cam.
There are other ways to improve your engines efficiency and performance, going strait to the cam is not my 1st choice with this power plant. In fact, the cam is more like the last thing I would consider.
SWE_lollo03
Sweden
Oh really? What other things should i do first to improve the performance?
19Walt93
4,484
Canaan,NH
351
3"
235/55R16
I got one from Camcraft that worked good in a stock rebuild. My copy and paste skills failed me but here's his contact info.
Walt,
I have attached the timing card for the 2.9. Cam part # 39-0206-9A7 HCR, lifter part # CHT-2083-12. Price for cam and lifters is $285 plus shipping.
Please let me know if you have any questions.
Thank you,
Hunter Webb
828-681-5183
442 Phillipsville Loop
Canton, NC 28716
