Can I layer over the door vents?
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
Going to sound deadening the doors and was wanting to just put material over the door vent. Would that cause some problem?
8,372
The door vent is to prevent rust inside the door, allows air to circulate and dry out moisture that comes in at the outside window seal
You may be able to put vent holes in the rear door jamb, but you don't get the benefit of the drier cab air to suck out the moisture
Make sure the drain holes in bottom of door are clear, I always add more drains in my doors
And you could spray a coating inside, bottom 1/4 of the door, to prevent rust, keep drains clear
Gozi
27
Garland, TX
Ford Ranger XLT
P235/75R15
Thanks Ron. Im cleaning the inside of the door now. Inside is actually really clean, but the bottom has a bit of overspray of adhesive. Its coming off but slowly. No rust anywhere.
8thTon
--- Banned ---
806
Pennsylvania
My world is filled with stuff that needs to be fixed
They are part of the ventilation system. They allow air to move from the cabin into the doors (bypassing the door seals), and from there out through the louvers in the outside lower edge of the door. If you block them the blower will have a hard time moving air unless it's on Max AC (recirculate) or the windows are open.
Ranger850
Doesn't get Sarcasm . . .
4,696
Tallahassee Florida
Stock 2"
Stock
they don't look bad. i would just leave them alone. if you're worried about them rattling, just remove them, but leave the hole to let air through. it can't rattle if it ain't there. lol
