Can of PB Blaster went "limp" from laying on its side... sheeeeyit...
fixizin
FoMoCo is forcing me to buy a 'yota
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
A properly suspensioned Ranger can be safely airborne for up to 4 seconds at a time! =:O
After decades of never buying WD-40... but always having several cans on hand... because peeps kept giving me theirs after they bought PB-Blaster... I decided to treat myself to the big PB--fancy can with the swing-nozzle, used it ONCE, and SO MUCH better results than WD-40, BUT... riding around in the bed-box, somehow it tipped over on its side for a couple months, and apparently all the propellant leaked out, but not the PB-juice itself, still 95% full, but only after extreme shaking can I get maybe a single drop to eek out! Frustrating!
SOOOooo... do I leave it out in the hot sun every time I want to use it, hoping that pressurizes the 0.1 cc of propellant left?... or just punch holes in the can and drain it all into some kind of hand-powered spray-bottle?
pjtoledo
3,019
Toledo Ohio
Fords
3.0 2.3
protect your eyes, even limp cans can squirt a couple feet when punctured.
is it really limp, like you can dimple the can with your hand pressure, or just plugged up?
PetroleumJunkie412
Official TRS EV Taunter
6,565
Dirtman's Basement
2.9l Trinity
Cool trick
Take off cap/push nozzle
Put new tire air stem over metal nipple on can
Charge with compressor
Works almost every time.
fixizin
114
Ft. Lauderdale, FL
XL Spurt
3.0 (Flex)
I can dimple the can... and just a faint whooshing sound when button pushed... but solid tip about EYE protection!...
... now I just have to find a spray bottle that won't be dissolved by the PB... something tells me the dollar store specials I use for 91% alcohol and hydrogen peroxide might not cut it... do they still make those old-timey metal oil-cans with the trigger-pump?
scotts90ranger
4,541
Dayton Oregon
2.3 Turbo
What PJ said about pressurizing it with air does work, I've done it with spray paint until the tube really plugged... :)
It sounds like you just got a defective can...
ericbphoto
Overlander in development
TRS 25th Anniversary
16,784
Wellford, SC
3.0L
6"
I’d jus poke a hole in it and pour it into another container, like an old style pump oil can. Use as normal. I’ve had cans of WD go flat after just sitting too long. It happens.
We’re so spoiled by aerosol cans.
superj
2,735
corpus christi, texas
ranger edge
none
none
235s
drives a stick shift ranger
Pb always loses pressure, even sitting up. I dont know why or how though.
I have it and use it alot but after sitting in the ac'd garage for to long, its dead
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Half of my cans have no spray tips. All it has to do is be anything except perfectly upright, tip flies off...usually in a broken manner so I cant pop it back on or use the can...most of the time I will try 50 different from other cans, none will work. I shoot a lot of cans.
