Can pour concrete on asphalt to make it flat again?
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
skyjacker front leveling kit
31-10.50R15
Crossed threads are tight threads.
Theres big tree roots pushing up the old asphalt around my garage, its a a real PITA rolling floorjacks and whatnot when Im wrenching. Can I just pour a thin layer of concrete over it to smooth things out? I think theres enough slope compensation to be able to float out over the roots yet keep drainage away from the garage...It wont be flat, but still better than these dang bumps....I dont wanna go through the cost and headache of having it all busted up and replaced just yet...For I may just teardown later...1st world problems...
MikeG
752
central Texas
B4000
2"
235/75r15
Sure, till the tree roots push it up again.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
Just put gravel over it...
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Its already gravel. I need to roll a floorjack and creeper around....
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
Well, what if I chipped out the asphalt, and formed it, but leaving surrounding asphalt to support the form...could I just fill it with mud and steel at that point? I could grind down the roots too I guess...
alwaysFlOoReD
5,164
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
You have to stop the roots from growing or it will happen again.
KILL THE TREE...
KILL THE TREE...
KILL THE TREE!!!
alwaysFlOoReD
5,164
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
KILL THE TREE...
KILL THE TREE...
KILL THE TREE!!!
Also, once the tree is dead the roots will decompose leaving a void in the dirt. How long that takes depends on moisture in the ground. So digging out the roots is a good idea.
MikeG
752
central Texas
B4000
2"
235/75r15
You tree-killer, you! Go stand in the corner and hug a bunny........
ericbphoto
Overlander in development
TRS 25th Anniversary
16,781
Wellford, SC
3.0L
6"
Can you? Yes
Is it a good idea? Not really.
Without removing the tree and roots, anything you do is temporary and will heave or break up again, meaning it's wasted money in time and materials. Its a lot of money and work to do it right. But it's more time and money to keep doing it over and over again. Personally, I would rather just deal with the lumpy driveway a while longer until I could save enough money to fix it right.. The choice is ultimately yours.
Eddo Rogue
2,505
Burbank,CA
Ranger 4x4
OHV
31-10.50R15
I cant mess with the tree because it is a protected oak. It looks old and dead, so it will probably fall over soon anyways. Its not even that bad, except for the spot that's ideal to park for wrenching. The aphalt is old an needs replacing anyways. Most of it is pretty flat, but I was gonna have it all re paved, but was thinking the part in front the garage could be concrete instead. Really I need a bigger garage.
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,871
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Depending on the root infiltration, you could just cut the roots effecting the pavement. I have a huge maple that has put roots everywhere. I had to cut a few when digging the gravel base for a retaining wall that holds the gravel base for the shed. The tree survived it just fine.
3,614
In the last 12 months I have kill both a tree and a rabbit.
MikeG
752
central Texas
B4000
2"
235/75r15
You'd go to jail in California for THINKING of hurting a tree root. Probably a public hanging if a bunny could prove that it's feelings were hurt.....
