Bronson with Bronco
- Oct 24, 2023
- 28
- Oregon
- Ford Bronco II
So I recently finished the 4.0 swap into my 84 Bronco II. Okay, I'll be honest, and say I'm not finished. It's running and driving and putting a constant smile on my face when behind the wheel (what a HUGE improvement over the 2.8!!), but I still have wiring to clean up and gauges to get working. But I digress.
I'm not able to get any Key On Engine Running codes. KOEO codes work with a test light no problem, and for those I'm only getting codes related to the automatic transmission the computer is looking for but is still in the donor vehicle. But when I try to get Engine Running codes, I get nothing. Nada. Zip.
I believe, after startup, it should at least signal the engine ID, but I don't even get this. The jumper and test light configuration doesn't change from KOEO to KOER, does it?
