Can't get it to idle - HELP!
franklin2
1,769
Virginia
Dude....
Put a bushing in it.
Or megajolt.
The bushings may be hard to find. I can get one if they turn out to be the same size as the common Ford distributor bushings in the v8 applications. If the bushing turns out to be oddball, I might have to get one made. This engine and I believe the 2.3 4 cyl were some of the first fully metric engines Ford used, so sometimes things are different inside.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
franklin2
1,769
Virginia
They don't sell the proper size for even the common v8. I don't know the OD, but the ID of the common bushing you can buy is 15/32. That is the shaft size of all the old Ford v8 distributors. They do make 15/32 reamers, but the cost is adding up. I just need to get out there with the calipers and measure what I have and see what my options are.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Make the bushing.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
Make a whole dizzy....
I know you can do it
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
cyclejohn
11
Reidsville, NC
Ford Bronco II
2.8 V6
I'll just put this right here:
John
Bronco648
102
Chicago-land, Illinois
XL
2.3
15"
franklin2
1,769
Virginia
Is "Powerspark" in Europe the same as "Duraspark" in the US?
~$165 total to have it shipped here. :unsure:
Reading the description, I would say no. That is a points style distributor that is using a conversion electronic module of some sort. Sounds like it hooks up like a Pertronix unit. If it is some oddball electronic ignition, you would probably need to keep a spare module in the glovebox.
