Catching up: My Bronco II build thread
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,718
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
That sucks about the title on the '84. Great vehicle finds over all though!
.38spl
48
Lake Barkley, Kentucky
6”
33x12.50x15
James 1:19
I was on a run there for a little bit. It’s been pretty dry lately.
franklin2
1,769
Virginia
Bronco II
Way back up in the thread I think you put a 4.10 rearend out of a ranger into your Bronco. Did you wack the spring pads off the ranger housing and move them to match the Bronco? I just did a ranger 7.5 swap on my Bronco, and ran into the problem of the pads being wider on the Bronco than the ranger. I forced the springs in and made it fit, but now looking at the pinion angle on the ranger rearend, its a little low. Don't know if it's going to give me problems or not, the u-joint at the diff is at a fairly radical angle. It's not pointing up like the Bronco rearend was. I have a feeling I am going to be redoing the spring pads, widening them and fixing the pinion angle at the same time.
BSwift
Oklahoma
Bronco II
What size tire were you running on the stock BII mags? If they are 31"s, what brand tire?
35022
