CB antenna ground
chewy012
Colorado Springs, CO
4.0 OHV
Just put a CB in the ranger. Mounted it to the bed tool box, which is bolted to the bed, which is bolted to the frame.... Which is bolted to the battery.
Is that a good enough ground? Should I run a wire straight to frame?
The antenna is only a 22", but it sits above the cab line by 6-8" in the center of the truck and clears the radio antenna by an inch.
Does it need to be raised?
Sent from my XT1254 using Tapatalk
chewy012
4.0 OHV
No, it came with a gutter mount clip (metal). I replaced that with a stainless L bracket. The base is mostly plastic, but has metal sections for contact with original metal bracket and coax.
AzLizard
13
TUCSON, AZ
1985
4.0 2.8
That nylon washer keeps it from grounding.
chewy012
4.0 OHV
Interesting, I would've expected it to need grounding. I'll through an isolator in there.
Thanks!
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
The antenna bracket itself must be grounded (bolted directly) to the toolbox, bed, whatever large metal surface it is attached to. The insulator is to keep the center radiating element (antenna itself) from grounding out against the bracket. So you would put the stud piece (w/star washer) through from below the bracket, then on top goes the nylon washer (shoulder facing downward into the hole), the flat steel washer (if one is present) goes next, and then the threaded sleeve that holds it all in place. Finally the antenna screws into the sleeve.
Indeed it needs to be (much) taller, but not by raising it's mount up...
The antenna itself is what needs to be taller (antennas that short IMO are a scam, they work so poorly). The longish 11-meter wavelength at 27 MHz (the radio spectrum CB uses) requires an antenna at least 48" tall in order to work at least somewhat acceptably (60-66" is much better, with a quarter-wave (102" tall) steel whip being best). Unfortunately there aren't many resources that tell you this though (or that at least make clear how important it is), which is partly responsible for the bad rap CB units seem to have gotten lately.
I run a 5.5' (66") Francis CB-26 Hot-Rod antenna w/heavy-duty spring on mine.
http://www.amazon.com/Francis-300-CB26B-Black-5-5-Antenna/dp/B007QXLS82
http://www.amazon.com/Firestik-SS-3H-Stainless-Antenna-Spring/dp/B00042LC9M
AzLizard
13
TUCSON, AZ
1985
4.0 2.8
What he said. Lol
chewy012
4.0 OHV
Awesome, thanks for the all the information. I know the 22" isn't good, but it was free from dad haha.
Looks like I'm in the market for an antenna!
Dangerrangers
Ohio
94 and 04
4.0 s
Do it right the first time !!!!!!!!!!
Check the truck stops they have a cb section with lots of cool stuff.
